Cleaning up engine bay
RE: Cleaning up engine bay
ORIGINAL: andywear87
i was wondering if anyone on here had pics of the whole process like which wires they tucked where and where they put alot of the stuff like selinoid coil
UNDER DRIVERS SIDE FENDER
UNDER PASSENGER SIDE FENDER
ORIGINAL: stang8689
Damn almost stock when did the s/c come? I guess I'll post a couple of my pics, its really worth it in the end. The wiring was actually the easy part.
http://www.allfordmustangs.com/Detailed/157.shtml
Agreed...hiding wires is not that difficult to do, it's only as hard to do as you want to make it to be.
2 yrs after I did what you see in those pics above I removed the dash and pulled all the vacuum lines and wiring harness inside because I didn't like the way things turned out in my 1st attempt. And since all my wire harnesses are now inside along with all the vacuum line I decided to re-route the brake line where they don't show either. And this winter......
