AOD Trans???
Old 10-23-2007, 11:57 PM
Hawaii 93 Stang
Hawaii 93 Stang's Avatar
Default AOD Trans???
Hey guys. Does my 93 Mustang 5.0LX have the AOD automatic??? Also there is one irritating thing. Why did they share 2nd and 3rd gear?? It goes 1,D, OD. If I change to a B&M shifter would that solve the problem of having a independent2nd gear or do I need to get a re-programmed valvebody?? Thanks for your help. Still learning.
Hawaii 93 Stang is offline
Old 10-24-2007, 12:01 AM
92GreyGT
92GreyGT's Avatar
Default RE: AOD Trans???
Unless some one changed it you have an electronic shift AOD. To get around your current shifter pull it back into 1. Take off and when it is time to shift move the lever up into D, when the transmission shifts pull it back into 1 and that will hold it in 2nd gear. When you are ready to shift into drive just move the lever. A shift kit and a different torque convertor will make a world of difference.
92GreyGT is offline
Old 10-24-2007, 12:14 AM
Hawaii 93 Stang
Hey there. Thanks!!!!! I just got the car last week and still finding and learning about these great cars!!!! I will try it.
Old 10-24-2007, 12:19 AM
nmerrill
nmerrill's Avatar
You can get a different valvebody, or do the epoxy mod. That will make the shift pattern 1-2-3/4. Instead of 1-2/3-4
nmerrill is offline
Old 10-24-2007, 12:20 AM
Ketis
Ketis's Avatar
epoxy mod?
please elaborate
Ketis is offline
Old 10-24-2007, 08:30 AM
capri debris
capri debris's Avatar
Just keep in mind that doing the 1-D-1-D shuffle is bad for the tranny, but will work... for a while.
capri debris is offline
Old 10-24-2007, 11:24 AM
Hawaii 93 Stang
ORIGINAL: capri debris
Hi. Yeah, that's what I was thinking too!! But I won't be doingthat all the time on the street. I just leave it in OD. But sometimes it sounds so good when you shift yourself!!!
Old 10-24-2007, 12:05 PM
PJB
PJB's Avatar
ORIGINAL: Ketis
epoxy mod?
please elaborate
Id also like to hear about that one.
Ive never heard of that before and Ive got an aod.
PJB is offline
Old 10-24-2007, 01:11 PM
98MustangGT46
98MustangGT46's Avatar
Here you guys go read up. This site is all about Automatic mustangs so save it.
Epoxy MOD
http://www.clickclickracing.com/forums/showthread.php?t=2817http://www.clickclickracing.com/forums/showpost.php?p=32594&postcount=47
PICS
http://www.clickclickracing.com/foru...p;postcount=47
98MustangGT46 is offline
Old 10-24-2007, 05:03 PM
shawnk007
shawnk007's Avatar
ORIGINAL: 92GreyGT
The AOD is not electronically controlled. Your thinking of the AODE....
shawnk007 is offline
Quick Reply: AOD Trans???
