line lock
Old 11-06-2007, 06:14 PM
highskewlmustnglvr86
highskewlmustnglvr86's Avatar
Default line lock
hello everyone well im about to buy a line lock kit and i was looking at the hurst kit,but i was wondering how hard it would be to install? also will it effect the regular braking?
thanks tyler
highskewlmustnglvr86 is offline
Old 11-06-2007, 06:17 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: line lock
won't even know it's therethat is of course until you use it you'll need to bleed the lines properly after install and make sure all fittings are tight....I installed one on a car about a month ago...worked great!!!
mjr46 is offline
Old 11-06-2007, 06:21 PM
ok thanks...also are there any special tools needed to install? like to crimp lines or cut them and things?
Old 11-06-2007, 06:32 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
You'll most likely need a flaring tool, tubing cutter, fittings and unions. Things like that.
PRO50SC is offline
Old 11-06-2007, 06:37 PM
ok thanks...is the hurst kit a good one?or b&m?
Old 11-06-2007, 06:39 PM
mjr46
mjr46's Avatar
hurst, I believe sells a installation kit that comes with all the lines and fittings..all you'd need after purchasing that would be a doubleflare tool...a customer of mine brought me in that with the line loc to install...it worked really well
mjr46 is offline
Old 11-06-2007, 06:58 PM
WhiteWindsor
WhiteWindsor's Avatar
I have the Hurst. The instructions are pretty easy to follow and they will tell you most everything you need.
WhiteWindsor is offline
Old 11-06-2007, 07:11 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Mines a Hurst as well and I also bought the installation kit. It will save you some trips to the auto parts store.
PRO50SC is offline
TCStangerv6
10-11-2015 05:57 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:58 PM
Quick Reply: line lock
