bypassing the heater core???
Old 03-09-2005, 07:32 PM
87 hatch
87 hatch's Avatar
Default bypassing the heater core???
i was in the process of replacing the heater hoses and accidentally broke one of the heater core inlet tubes. Can i just bypass the heater core all together by putting a loop hose on those two pipes from the engine? Is this normally done or do i have to replace the heater core.
87 hatch is offline
Old 03-09-2005, 07:44 PM
titan aresta
titan aresta's Avatar
Default RE: bypassing the heater core???
yup, just loop it to bypass the heater core.
titan aresta is offline
Old 03-09-2005, 07:45 PM
69mach1377
69mach1377's Avatar
You could probably get away with it, now that spring is coming. But you'll probably want to replace it in the fall.
69mach1377 is offline
Old 03-09-2005, 07:52 PM
87 hatch
87 hatch's Avatar
ya, i know im going to have to replace it but the books directions say that i have to completely drain the freon from the a/c and disconnect all those lines and then start on removing the heater core. would i be able to replace the core without doing all that other stuff?
87 hatch is offline
Old 03-09-2005, 07:59 PM
mustang8719
mustang8719's Avatar
I didn't do anything to my A/C to replace mine.
mustang8719 is offline
Old 03-09-2005, 09:02 PM
87 hatch
87 hatch's Avatar
thats good to here...
87 hatch is offline
Old 03-10-2005, 12:49 AM
Dan89lx
Dan89lx's Avatar
just loop a pice of hose from the top outlet of the intake tube to the bottom outllet and put a clamp on each end. I had to do that after I broke mine until I got it fixed.
Dan89lx is offline
Old 03-10-2005, 04:16 AM
87 hatch
87 hatch's Avatar
i just got done looping the hose from the inlet to the outlet using a reducer because the hoses are two different sizes. it looks like it will work but the hose is a little pinch in it. im not sure if that is a big deal or not. i looks like water will still flow, just a little slower. Maybe i will just go the distance and take my dash out and replace the stupid heater core...
87 hatch is offline
Old 03-10-2005, 04:35 AM
mstng675l
mstng675l's Avatar
Ya i had to bypass mine... When i bypassed it i pretty much pinched the hose off totally not sure if thats good or not but havent had any problems...
Not to hyjack the thread or anything but this is sortof on the lines of the coolant system.. Soo waht i was wondering was why my Water temp. gauge is tached out... When i wigle the connection it will drop the needle to 270 but after a while it will just work its way back up.. What is the problem??? would it be the gauge or the sensor??? i know im not running that hot because i would have water boiling over....
ORIGINAL: 87 hatch
mstng675l is offline
Old 03-31-2005, 04:47 AM
zoomy88
zoomy88's Avatar
I don't know what mustang you have but anyone i know that has replaced the heater core the AC has to be sucked empty.[sm=bustedsign.gif]
zoomy88 is offline
mrtrodonet
09-19-2020 03:12 PM
Roxon68
03-17-2016 08:13 PM
Seanam
10-04-2015 10:15 AM
TimeLord101
09-04-2015 09:27 AM
Calizic
08-28-2015 01:46 PM
Quick Reply: bypassing the heater core???
