Installing new plugs in my 95 gt?
Old 12-17-2007, 11:33 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Installing new plugs in my 95 gt? *Update*
use a 5/8 swivel/universal spark plug socket and long extensions and a rachet and you should be able to get to most...you may have to move the air injection stuff out of the way to access the ones on the passanger side..but it's doable
mjr46 is offline
Old 12-17-2007, 03:48 PM
OnyxCobra
OnyxCobra's Avatar
o_O I thought mine was tricky but I didn't ever think it was THAT hard...
OnyxCobra is offline
Old 12-18-2007, 01:31 AM
88GTMustang
88GTMustang's Avatar
Well I got another 3 done today. I just have the back one on each side to get now. In response to the above posts about time, I agree it is not that hard. My main problem is getting the plugs to seat. It is really difficult to get the plugs to thread into the holes properly and I am being very cautious to avoid cross threading. It is pretty frustrating getting these stupid things to thread in, not sure why they are giving me problems. must be all the rust around the area.
On the smog equipment can I undo those hoses? Is there any fluid or anything running through those lines?
88GTMustang is offline
Old 12-18-2007, 03:11 AM
w8less
w8less's Avatar
it makes things easier when you start removing stuff like smog and ac. i know i fuking hated changing the plugs. i have kind of big hands and cant hardly reach some of the crap
shibby if you did it in 15min id like to shake ur hand. i was never able to do it in that time
w8less is offline
Old 12-18-2007, 04:36 AM
Lordy
Lordy's Avatar
It actually could be worse. Chevy made a car in the 80's (Monza) that the motor needed to be lifted several inches (unbolted mounts) to change the plugs.
I recently did my 2001 Blazer (V6) that took me 6 hours to change the plugs and wires. I resorted to removing the front wheels and used long extensions thru the wheel well. Chevy engineers were even so smart they put one plug directly behind the steering shaft. I think my dogs learned a few new words on that one.
Lordy is offline
Old 12-18-2007, 10:38 AM
88GTMustang
Can I undo the hoses on from the smog pump? Anything in them?
Old 12-18-2007, 10:44 AM
94Yellow50
94Yellow50's Avatar
hey not sure if ur having problems gettin ur hand down to get the plug in the hole..buta way ive always used is take a piece of real small rubber tubing that u can slide over just the end of the plug..and i mean small like the size of a straw...take that stick the plug in then get the plug to the hole n u can turn the tubing from a long way away from the hole and it will turn the plug...i did this on a 4 cyl ranger for someone and without it i would have had to take the upper intake off cuz that motor is a b*tch to change plugs...stupid azz 8 plugs for a 4cyl...i hated doin that n will never do it again lol..
94Yellow50 is offline
TimeLord101
09-04-2015 09:27 AM
Emblazoned
09-03-2015 10:45 PM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Installing new plugs in my 95 gt?
