upper and lower controls arm
Old 12-15-2007, 11:31 AM
andywear87
andywear87's Avatar
Default RE: upper and lower controls arm
why only that setup do you not like the upr rear kits or any others not trying to be arguementive but you are a very smart guy about foxes and want your input.
ORIGINAL: r.barn
Wont feel a ton of dif with gear swap, little bit though.
Get Maximum Motor Sports lower control arms and Ford Racing Uppers
only way to go.
andywear87 is offline
Old 12-15-2007, 08:13 PM
roostracing
roostracing's Avatar
fox's, sn's, and new edge all have the same suspension set ups...SETTING UP YOUR SUSPENSION CORRECTLY will dictate how well you like it!!!
roostracing is offline
Old 12-15-2007, 08:45 PM
r.barn
r.barn's Avatar
The avg. joe does not know how to set adjustable control arms,
will never readjust them and doesnt need to.
Upper control arms dont really take any real "load" so stock
design is fine and keeps pinion angles at factory settings which is fine
for a "street" car. The Ford Racing uppers give you a stock arm with
slightly stiffer rubber bushings to firm up suspension "slop" in turns.
I have MM's that have urethane on one end and spherical bearing on the other
and dont find the ride any rougher than with worn out stockers.
Everything I've read says people have binding issues when cornering
with pure urethane bushings on both ends.
r.barn is offline
Old 12-15-2007, 09:22 PM
nacanitihs
nacanitihs's Avatar
im gettin these soon http://www.uprproducts.com/shopping/shopexd.asp?id=367
nacanitihs is offline
Old 12-15-2007, 10:26 PM
roostracing
you are right about the average Joe not knowing how to properly adjust control arms...i found that i never needed an adjustable lower...but the upper adjustable for ME is something that i will always need especially at the track...just by replacing the stock bushings for a nice urethane one will help dramatically...
lincolnshibuya
07-05-2020 03:05 AM
baddog671
07-26-2016 01:20 PM
UrS4
10-03-2015 06:23 AM
ChampInSD
10-02-2015 04:55 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: upper and lower controls arm
