mixed combo works!!! 1.6 intake/ 1.7 exhaust
makes some good power with a trick flow st1 cam!! but also make great power with others as well i have AFM b451 cam and it put down power...... who else have this set up like me? 1.6 intake and 1.7 exhaust side rollerrockers? and sees the same results......
RE: mixed combo works!!! 1.6 intake/ 1.7 exhaust
I saw an article in 5.0 Mustang where they were testing different roller rockers and they did just this for one of the dyno runsand picked up something like 5-10 hp over all 1.6 or all 1.7s. People say that our engines are a tad biased to the exhaust side and I guess this shows it.
If you really want to fly, then get a set of Trick Flow heads and put Chevrolet 1.5 roller rockers in it. Im using this for my Pure Street Combo. It puts less stress on the valvetrain for longer life and also allows for higher RPM. One of the reasons to do it is it lets you run a bigger cam profile (we are held to .500 lift on hyd. roller cams).Not a cheap thing to do, but definately worth it. Harland Sharp makes a kit for around 399 (Stud) and 1099 (shaft) mounted applications.
I dont get it, the exhaust is so bad on the ford small block, why not put the 1.7 on the intake side? Do like the bbf cams do, they favor the intake cause the intake is soo much better. if it were me I would put 1.7's on the intake and 1.6's on the exhaust
i remmember posting this up a few months ago. some one told me if you already have 1.7's there is not point going down to 1.6's, and it doesnt make a diffrence. thats why i never tried it.
