4 degree cam advancing ? Help
Old 09-30-2003, 12:09 AM
T5superduty
T5superduty's Avatar
Default 4 degree cam advancing ? Help
Hey I have a ford racing motor and they told me for sure to advance the cam 4 degrees. do you know how this is going to effect my car at all. good bad what ? Cause my machanic had no idea why it would need to be advanced but we listend to ford racing and did it. any ideas why ?
T5superduty is offline
Old 09-30-2003, 12:15 AM
nostang
nostang's Avatar
It's suppose to give you a little more bottom end and a little more vacuum at idle.Most cam companies grind the 4 degrees of advance into the cam,so if you install it without using an adjustable timing gear it will allready be advanced,but you need to read the cam spec card to make sure.
nostang is offline
Old 09-30-2003, 12:17 AM
T5superduty
Oh man so you think my car wont be having too much high end horsepower ?
Old 09-30-2003, 12:33 AM
nostang
nostang's Avatar
Did you degree the cam in with a degree wheel or just advance it 4 degrees on the crank sprocket?
nostang is offline
Old 09-30-2003, 12:59 AM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
Advancing a cam, in general, will hurt top end in favor of bottom end. You will get a noticible increase in bottom end and wont notice much in top end... but you better be sure you need to before you do.</P>
mdvaldosta is offline
Old 09-30-2003, 01:49 AM
T5superduty
He just turned the crank sprocket 4 degrees</P>
Is that good bad ugly ?</P><edited><editID>T5superduty</editID><editDate>37894.6181481481</editDate></edited>
Old 09-30-2003, 04:58 PM
T5superduty
Please god someone tell me what I should do I am about to fire the engine! <IMG src=smileys/smiley19.gif border="0">
Old 09-30-2003, 05:02 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
If the company you purchased the cam advised you to install it 4* advanced, then do it. Your not gonna f*ck anyting up either way, you just may have to reinstall the cam if it runs like a$$
Old 09-30-2003, 07:34 PM
T5superduty
But was it degreed correctly ? We just turned the crank sprocket 4 times
Old 09-30-2003, 08:14 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
Well, you don't HAVE to degree the cam, but degreeing the cam simply means to checking to ensure the cam matches the specs on the cam card, and ensuring your cam gives the desired lift and duration with everything bolted up. Rarely is a cam misboxed or your cam or crank gear mis-idexed etc, but a good engine builder will always be safe and degree the cam. By degreeing, you also find the intake centerline, ensuring you know whether you need to advance the cam or not.</P>
But hey, I can't tell you I have degreed every cam I put in, and in all honesty I only degreed the first one I ever did (shhhh just between us) in a car (I do degree all my kart racing engines though . The only reason I degreed the kart motors was because of having to meet WKA specs, and vavtrain variation will give different lift and dur even with the same cam.</P>
You'll be fine as long as you needed to advance it. If you didn't need to and the advance was already ground into the cam, then you just lost about 10 hp.</P>
Quick Reply: 4 degree cam advancing ? Help
