What MAF for 30lb injectors
Old 12-19-2007, 05:36 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: What MAF for 30lb injectors
ORIGINAL: lmatt
I have part # m-12b579-a70 MAF sensor. I was having problems running VERY lean and burning valves. Thats why someone suggested to put the 30's in.
OK, you gave us a part no. Does nothing to help. What kind is it and is it calibrated for the injectors?
PRO50SC is offline
Old 12-19-2007, 11:29 PM
w8less
w8less's Avatar
ORIGINAL: primetime5.0
ORIGINAL: Jasperstang308
was the car tuned properly?
tuned for what? just having heads?
haha completely missed the mods he listed
w8less is offline
Old 06-08-2014, 05:32 AM
madman05
madman05's Avatar
Default mass air flow
I have a stock 302 and it does not have a mass air flow sensor and want to upgrade my cam to a E303 do i need to add a MAF system.
madman05 is offline
Old 06-08-2014, 06:06 AM
dawson1112
dawson1112's Avatar
You should really start your own thread, this one 7 years old.
But to answer your question, I always recommend a MAF convertion for any SD car that you plan on upgrading. Since the MAP is so reliant on proper vacuum , adding the wrong cam will cause you headaches ..
They do make some cams that are supposedly SD friendly.
dawson1112 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
Dathan
10-05-2015 05:52 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: What MAF for 30lb injectors
