vacuum pressure?
Old 12-20-2007, 02:19 PM
91camaroeater
91camaroeater's Avatar
Default vacuum pressure?
what should the vaccum pressure be at idle? i have a powerdyne charger on the car and it idles just at 1,000 rpm. thanks
91camaroeater is offline
Old 12-20-2007, 02:30 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: vacuum pressure?
vaccum pressure???..........just vaccum you mean?? pressure is the opposite of vaccum...antway a stock motor should be from 16 to 19 inch hg
mjr46 is offline
Old 12-20-2007, 04:06 PM
dillon1340
dillon1340's Avatar
ORIGINAL: 91camaroeater
just at 1,000 rpm? that sounds kinda high to me.
dillon1340 is offline
Old 12-20-2007, 04:42 PM
fourfivefour
fourfivefour's Avatar
Why do you ask?What is your vacuum? Too low and your vacuum assisted power brakes will not function properly.
Your boost/vacuum gauge may be NFG. Try another gauge. Your gauge should be connected directly to the manifold so you don't get a false reading.
Are you running a blow off valve?Valve should be open at idle.
What cam are you running? With a performance cam your vacuum will be lower than stock.
The cam manufacturer should be able to tell you how much vacuum you will get at idle.
With a really big cam you may only get -10 vacuum.
fourfivefour is offline
Old 12-21-2007, 09:08 AM
91camaroeater
i just read my own question,lol. what should vaccum read?
at idle, which is 1,000 rpm, it reads around 12, its has a supercharger on it which peaks out at 6 lbs, e303 cam, trickflow upper/lower,heads.
the line goes into the back on the intake manifold and ive check it to make sure it is tight there and at the guage.no leaks
the reason i ask is i havealot of oil on the back of the motor and i dont know where it is coming from. ive cleaned it up but still comes back, it seems to run down the top of the heads and on top of the trans .
any help would be nice. thanks
mrtrodonet
09-19-2020 03:12 PM
baddog671
07-26-2016 01:20 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
SteelerNation82
09-16-2015 07:11 AM
Quick Reply: vacuum pressure?
