Replaced inner pinion bearing, bearing race, outer pinion bearing, outer race, and is still singing away. Is this
common for the 5.0 stock differential? Any suggestions to quiet it down.
has it always made noise? the noise usually comes from a bad gear pattern. you checked the pinion depth and backlash right? if they are used gears you may never get it to stop making noise even with a good backlash and pinion depth.
