car stalls
car stalls
Hi I have a 90 GT wich is having the same problems as some others here with the irratic idle. I am going to replace the IAC tomorrow and see if that helps. </P>
The other problem I have is my 90 GT 5 speed will stall when putting in gear. I can hold clutch to floor and put shifter in 1st and the car will die, without letting the clutch out. Could the IAC have something to do with this stalling? Any help with this would be great.</P>
car stalls
Or the EGR, or vacuum pressure, or throttle body position, it could be a number of things, im having the same problems too, but my idle is now at like 2000 rpms, i think i have a vacuum leak
car stalls
1st thing to do is clean the IAC valve or ISC motor(whatever you wanna call it), its on the throttle body, just take it off and clean it with brake cleaner. Then check your TPS voltage to ensure it is where it needs to be. You can also spray carb cleaner around all your vacuum connections,vacuume lines,and egr valve to ensure you have no leaks (your idle will change if you spray on a leak).
car stalls
Check your tps voltage.. key on engine off it should read .96 - .98 volts. Be sure to ground through the plug too. Its kinda hard to check it cause you gotta do it inline. I make jumper wires from the plug to the tps and check voltage from the jumpers.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
