Restoring Compression for a 94 gt 5.0 h.o.
Old 01-08-2008, 10:50 PM
Rbirdsong82
Rbirdsong82's Avatar
Default Restoring Compression for a 94 gt 5.0 h.o.
What is the best way to restore compression in my 1994 mustang GT 5.0 H.O.?
Rbirdsong82 is offline
Old 01-08-2008, 11:32 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Restoring Compression for a 94 gt 5.0 h.o.
if you watch tv late at night there is a infomercial that comes on and it's called "engine restore" made by I think durabond...that claims to add 30 to 40 percent of lost compression back to a motor by filling in scratches in the cylinder walls!! no joke the product really exists!!!!!! lol lol.......anyway..best way is rebuild the motor/ overhaul it
mjr46 is offline
Old 01-08-2008, 11:59 PM
89Ford
89Ford's Avatar
how bad is it? you could try some Lucas oil additive
89Ford is offline
my77stang
my77stang's Avatar
thick oil my nukka
my77stang is offline
Old 01-09-2008, 06:36 AM
tooslow5.0
tooslow5.0's Avatar
engine restore does work, and work well. but its only a bandaid, you have to add it to your oil every oil change. you could add that and some thicker motor oil, but expect your mpg to drop some. restore is at any autoarts store. what is your compression anyways? have you actually checked it? or is it just feeling sluggish?
tooslow5.0 is offline
Old 01-10-2008, 01:26 PM
Rbirdsong82
Ive already used the "restore" i got from the parts store but it doesnt seem to be working much.
Old 01-10-2008, 06:30 PM
tooslow5.0
tooslow5.0's Avatar
again, have you ran a compression test on your car? cause it might not be that at all....
Old 01-10-2008, 09:55 PM
Twisted
Twisted's Avatar
Engine restore wouldn't do a thing if compression is being lost through the valves. But, yeah, have you or have you not done a compression test? Assuming you have, you need tofollow witha wet compression test to figure out where you're losing pressure. Only then can your question be answered. Good luck.
Twisted is offline
Old 01-10-2008, 10:33 PM
mjr46
mjr46's Avatar
DETERMINE THE root cause and rebuild the motor if necessary
mjr46 is offline
Old 01-11-2008, 02:53 AM
greenstreak9205
greenstreak9205's Avatar
ORIGINAL: mjr46
you have to put in different crank along with longer rods. nitrous may help also
fixed that for ya
greenstreak9205 is offline
baddog671
07-26-2016 01:20 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
jrrhd73must
10-02-2015 09:17 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Quick Reply: Restoring Compression for a 94 gt 5.0 h.o.
