GT40X and stock rockers...
So as some of you may know, my brother just put GT40X heads on his fox. Well he bolted the stock rockers onto them and torqued to 18ft. lbs... When driving the car, it has a really hard time accellerating but it doesn't pop or sputter at all, it just feels like the valves are really tight. Should he have brought each cylinder to TDC on compression and then torqued to 18 ft. lbs. or does that not matter??? Thanks
RE: GT40X and stock rockers...
well if they are pedastal mount stock ones the best thing you can do is trash them....I believe if stock rockers are used on performance aluminum heads ...not sure about the ford ones but any other ones like afr the stock cockers have to be clearanced a little or they will interfere with the retainers on the springs.....but either way..I'd of put a set of roller rockers on.....stock rockers on a performance head = take a step backwards in performance[:'(]
You need to check the preload on the lifters. 020" to 040" preload is optimum. If you can get access to a comps cam catalog, they have detailed instructions on how to do this. You can also run a compression check. Any valves that are being held open will show-up with little to no compression in that cylinder. Crane makes a very inexpensive shim kit so you can adjust the preload on the lifters that will allow the valves to close. You may have to install shorter pushrods as well. I had this happen to me on my HCI swap, and I have shims on three cylinders. That's the breaks with having a pedestal style rocker. Never again for me.
ORIGINAL: 91hatchgt
Thanks, but that didn't answer my question at all.
mungodrums
09-29-2015 09:18 PM
mungodrums
Suspension
09-24-2015 10:12 PM
ccdguy
09-19-2015 05:20 PM
