what RR and Springs??
Old 01-10-2008, 11:49 PM
Alero99
Alero99's Avatar
Default what RR and Springs??
My set up will be
GT-40 cast iron (id like to aviod Ps but i dun think the difference will be that major)
TFS-51402000 cam
Cobra Upper and lower, lower ported a bit
so should i run 1.6 or 1.7 RR and what springs should i be getting?
edited sorry copy and pasted wrong thing...
Alero99 is offline
Alero99
Alero99's Avatar
Default RE: what RR and Springs??
btw the internals will remain STOCK
Alero99 is offline
Old 01-10-2008, 11:56 PM
dimebag
dimebag's Avatar
specs on the cam?
dimebag is offline
Old 01-11-2008, 12:36 AM
92GreyGT
92GreyGT's Avatar
I beleive this is the cam:
http://store.summitracing.com/partde...p;autoview=sku
As far asusing 1.7 ratiorockers with this cam theintake lift would be .530" and exhaust .541". This would be fine but with stock pistons this may cause you some piston to valve clearance issues. I have personally used this cam with 1.6 rockers, stock pistons and had no probelms.It hada goodsound and good performance. Iwould callTrick Flow and ask which valve springs they reccomend for this. Make sure and check your springinstalled height before you call because that is going to be their first question.
92GreyGT is offline
Old 01-11-2008, 01:58 PM
Alero99
Alero99's Avatar
what kinda power am i expecting from this cam most ppl telling me to expect 274-290 from this set up... is there a better cam for that set up? i can most def 280+?
Alero99 is offline
Old 01-11-2008, 02:51 PM
Mustangkiler
Mustangkiler's Avatar
Id expect 250-275 with your setup, that cam and steeda aregood cams you cant go wrong with either and are affordable,unless you want to spend money on a custom.
Mustangkiler is offline
Old 01-11-2008, 02:55 PM
83gtragtop
83gtragtop's Avatar
250-260 rwhp.....gt40's limit you
83gtragtop is offline
Old 01-12-2008, 12:56 AM
Alero99
Alero99's Avatar
what about port job on the lower intake?
Alero99 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
CS2007
06-25-2019 09:45 PM
Gene K
10-21-2015 11:37 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: what RR and Springs??
