paint for headers...
Old 01-14-2008, 06:59 PM
DoctorD415
DoctorD415's Avatar
Default paint for headers...
The headers on my mustang have some surface rust on them and i was wondering if there is any paint that would withstand the heat that i could put on them. Would the high heat engine enamal spray paint by duplicolor work for headers? It says 1200 degrees.
DoctorD415 is offline
Old 01-14-2008, 07:48 PM
bobbyboura
bobbyboura's Avatar
Default RE: paint for headers...
the duplicolor suff is acuallyprey ood is wha i use
bobbyboura is offline
Old 01-14-2008, 07:52 PM
DoctorD415
DoctorD415's Avatar
can u rephrase that a bit, lol. Are you saying its good and it would withstand?
Old 01-14-2008, 08:11 PM
86 GT 5.0
86 GT 5.0's Avatar
I sprayed mine with the VHT and it's still holding up..
86 GT 5.0 is offline
Old 01-14-2008, 08:18 PM
tinman
tinman's Avatar
I've been using VHT for 30+ years.
The thing with it is to have the headers REAL clean, sandblast the old rust off them, then wipe them down with lacquer thinner.
Headers should be at least at room temperature. Living in Arizona, I just put them out in the sun for awhile.
Light coats of paint, several. Let them dry for at least 24 hours and you're done.
Sounds like a lot of work but it's worth it......
tinman is offline
Old 01-14-2008, 09:46 PM
OnyxCobra
OnyxCobra's Avatar
I strongly recommend staying away from Duplicolor header paint. I used it before and it blistered off the first time i ran the car.
VHT Flameproof paint FTW! I redid my headers with VHT header paint and it looks MINT!
Note: Do not use any more paint than you need to cover the surface, excess paint can cause ugly results.
OnyxCobra is offline
Old 01-14-2008, 11:58 PM
The Stig
The Stig's Avatar
Is VHT only paint? Or is it like a coating to keep in the heat too?
The Stig is offline
Old 01-15-2008, 12:25 AM
wildsurfer92
wildsurfer92's Avatar
what color did you guys paint your headers when you did them?
wildsurfer92 is offline
Old 01-15-2008, 05:45 AM
DoctorD415
DoctorD415's Avatar
i was thinking about doing a flat silver/grey. Any other recommendations on colors or anyone have pics of theres?
Old 01-15-2008, 06:07 AM
mantis118
mantis118's Avatar
Id say black.
mantis118 is offline
Quick Reply: paint for headers...
