need your help screwed um my tires bad tonight!!!!
Old 01-15-2008, 09:58 PM
blk89lx
blk89lx's Avatar
Default need your help screwed um my tires bad tonight!!!!
ok well i just put on my 17x10 with a 285 tire in the rear. i had to remove quadshocks so that left me with stock upper and lower c/a's. i have eibach sportline springs also. i hit a big bump and the tire ripped down the inner lip of the quater and shredded tire. im so mad what can i do to stiffen up the rear and stop it from rubbing. i was thinking a stiffer spring sum c/a's. please any help would be great.
blk89lx is offline
Old 01-15-2008, 10:24 PM
keek89gt
keek89gt's Avatar
Default RE: need your help screwed um my tires bad tonight!!!!
i dont know how to stiffen up the suspension but if you do, you will lose traction and be back to sqare one with the stocker 225's on there. i know this is out of thequestion but try a lower profile tire or you could also try rolling the lip on the fender, how much of the lip is rubbing if your tires are sticking out the id say your s.o.l
keek89gt is offline
Old 01-15-2008, 10:32 PM
blk89lx
blk89lx's Avatar
not sticking out much pretty mch even with the fender well. is it possible the stock rear control arms are not absorbing bumps good like its not stiff causing rear to sink alot on bumps. plus i think my springs are too low
blk89lx is offline
Old 01-15-2008, 10:38 PM
bighungrymatt
bighungrymatt's Avatar
get some aftermarket upper/lower control arms
bighungrymatt is offline
Old 01-15-2008, 10:40 PM
stang8689
stang8689's Avatar
The main prob is sportlines lower more than any other spring. If anything polyurethane upper and lower isoltaers will help
stang8689 is offline
Old 01-15-2008, 10:41 PM
blk89lx
blk89lx's Avatar
i have both isolators in maybee new springs?
blk89lx is offline
Old 01-15-2008, 11:04 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
grind the inner lip off with a die grinder or get skinnier tires
mjr46 is offline
Old 01-15-2008, 11:07 PM
Mustangkiler
Mustangkiler's Avatar
Prty muchi had same problem with some slics 10.5 mickeys and tore off the inner lip, you need to either get a skinnier tire or grind away inside the inner part of the fenderwell, when i took the tires off i could see the line where they were scrapping across the inside of the fenderwell, at least mine were used tires so i wasnt out too much.
Mustangkiler is offline
Old 01-16-2008, 12:23 AM
83gtragtop
83gtragtop's Avatar
Trash the sports and go with eibach pros. You will still have the problem with the sports no matter what, thats just to low.
83gtragtop is offline
Old 01-16-2008, 08:51 AM
94RedDevil
94RedDevil's Avatar
I've got your solution but it will cost you about 200 bucks. Granatelli makes a lower control arm that allows you to lower your car 1 inch or raise it up to 2 inches. I have these on my car because I was having a similar problem. Look into them, jegs has them for 199 and they ship them to you in like 2 days. You have to get the lower controls with the weight jacker.
94RedDevil is offline
Quick Reply: need your help screwed um my tires bad tonight!!!!
