Do I need a Boost controller?
Hows everybody doing? Ok I am getting my car Dyno tuned and wanted to know the benefits of keeping my Boost controller ( it is the MSD Boost Timing Retard Unit). My thoughts are once its setthats it right (set it and forget it). Its a street car with the occassional 1/4 mile pass. My other concern is my daughter playing with the controller ****, that can really screw things up right? Its mounted just under the dash. Any input to the advantages and disadvantages would be greatly appreciated it.
Specs:
Engine Information[/b]
Ford Motorsport X302 bored .010 (306) with Motorsport forged pistons (8000 miles)
1.6 Ford Motorsport Roller Rocker arms
GT40X302 aluminum heads
Ford Motorsport "E" Cam
Trickflow intake
BBK adjustablefuel pressure regulator
Vortech S-Trim V1 Supercharger 10 lbs. Boost
BBK 70mm Throttle body
BBK 70mm EGR plate[/ul][/ul]
Other Information[/b]
BorlaCat Backexhaust
BBK equal length shorty headers
Bassani Stainless Steel X pipe with cats.
Centerforce Dual Friction clutch
Pro-M Bullet 75mm mass air meter
Afco Radiator
Eaton electric fan
42lb Fuel injectors
MSD 6 BTM boost timing retard unit
MSD 6AL Ignition
MSD coil
255lph in tank fuel pump
Vortech T Rex external fuel pump [/ul][/ul]
Specs:
Trickflow intake
Afco Radiator
Eaton electric fan
42lb Fuel injectors
MSD 6AL Ignition
MSD coil
RE: Do I need a Boost controller?
with a tune BTM,FMU's are not needed unless your going to try and run more boost or race gas.if u get a tune on 93 octane run 93 octane.so if your going to get a tune and leave it alone.don't really need the BTM.
ORIGINAL: 2burnouts
Hey Pro50SC, I live in Pasadena MD so I know what you're talking about. When I get the tune next week I am having them remove the FMU. I'm still up in the air about the Boost Controller. Should I upgrade the Fuel rails while I'm popping in the new Injectors for future Fuel upgrade? I can't wait to see what the HP is, should be 450 to 500 atleast I hope.
ORIGINAL: Vetkilr
Hey Pro50SC......I joined the mustanggt forum. I don't belong to any local clubs but would like to. ELD is going to perform the Tune...they are located in Millersville MD. Thanks
Hey greenstreak9205......Thanks I thought it was getting pretty close. I'll find out mid next week what its putting out.
Do you know those guys. I have heard mixed reviews. I'll send ya some links (pm) w/ some clubs. A new one just started up and there are a few guys from your area. Already had a couple meets, really nice ppl. The next one is in Feb. You should try and make it. Gonna be in Gaithersburg this time. Since the group is from so many areas, we're picking spots around the metro area to make it easy for everyone to attend.
jwog666
12-27-2021 08:09 PM
