Stall question
Old 01-23-2008, 01:18 PM
stangman94
stangman94's Avatar
Default Stall question
When you add a stall to your car say 3200 does it just help you on your launch or does it as well free up some horsepower?
stangman94 is offline
Old 01-23-2008, 01:42 PM
golden_eye
golden_eye's Avatar
Default RE: Stall question
I'm a little weak on my auto trans knowledge, but I believe whatis meant when you have a "3200 stall" TC (for example) is thatthe torque converter you have installed is set up so that it is fully locked at that RPM. What this means is that you can launch the car harder and more or less the same as if you were to launch a manual at that RPM, execpt you will be much more consistentsince it's harder to mess up a launch in an auto.
I don't know about freeing up hp but I heard that having a high stall car isn't very good for daily driving as the TC will be unlocked and slipping most of the time which will lead to increased wear and higher trans temps
golden_eye is offline
Old 01-23-2008, 02:48 PM
tylerl90
tylerl90's Avatar
You hit the gas, and when your car hits the set rpm's(which will be fairly quick) it will launch.
tylerl90 is offline
Old 01-23-2008, 03:13 PM
stangman94
stangman94's Avatar
ORIGINAL: tylerl90
No **** I am perfectly aware of that I know how a torque converter works but I asking if it frees up some horsepower. Someone told me that before but I dont understand how that could work.
and I'm not going to run a 3200 tc I'm undecided what I'm going to put on but I'll be getting a transcooler as well. Hell I might not each get a tc it all depends if I rebuild the motor or not
Old 01-23-2008, 04:16 PM
tylerl90
tylerl90's Avatar
ORIGINAL: stangman94
ORIGINAL: tylerl90
Pardon me..
I don't see how it'd free up horsepower when all it really does it cause worse transmission wear and heat.
tylerl90 is offline
Old 01-23-2008, 06:45 PM
nitrous_bob
nitrous_bob's Avatar
if you go less than 3200 don't bother at all
a 2200 will feel stock, since you will get about 500 rpm less than advertised stall speed
a 3200 will flash roughly 2700-2800 so make sure you really shop well, and don't get a cheap one either or it will be worse. stick w/ lentech or precision
nitrous_bob is offline
Old 01-23-2008, 08:11 PM
FLcracker9
FLcracker9's Avatar
ORIGINAL: nitrous_bob
+1.
A stall converter doesn't free up horsepower. It lets the motor build more rpms before locking the motor and tranny together, preferably in the motor's powerband(I know you said you already know this). Like nitrous_bob says, the converter will flash at a lower stall speed than advertised. It all depends on your motor (camshaft), gear ratio, and the weight of the vehicle it's trying to push. There's no such thing as buying an off the shelf converterthat will perform as advertised in every model in which it will fit. Best way is to contact the manufacturer, and give them your specs, and they can match up a converter for you.
FLcracker9 is offline
Old 01-23-2008, 08:59 PM
stangman94
stangman94's Avatar
ORIGINAL: FLcracker9
+1.
Thankyou will do I didnt know about them letting loose earlier then what they say.
Old 01-23-2008, 09:10 PM
fourfivefour
fourfivefour's Avatar
It won't free up HP. It will allow you to hold more rpm's at the starting line before the tires start spinning.
The biggest reason for having a stall converter is with a modified engine you can't idle low enough to keep it from stalling when you put it into gear. Also the stall speed will allow you to bring up your rpm's at the starting line before launching to get into the power range of your engine and cam.
Example: A cam that has a power range of 4500-7500. With a stock converter the car would fall flat on its face. With a 4500-5000 stall converter you could get your rpm's intoits power range and launch hard.
fourfivefour is offline
Old 01-23-2008, 09:47 PM
aode08
aode08's Avatar
A stall with reduce your 1/4 mile times, by at least .3 alone.
A stall matched up to the engine's camshaft and overal setup will produce optimal results.
You can make a car faster without horsepower, stall converter, gear ratio change, weight reduction and suspension modifications.
aode08 is offline
Quick Reply: Stall question
