Im about to sell my car (not really, im just fustrated)
RE: Im about to sell my car (not really, im just fustrated)
First off, no matter how bad my car becomes, I will never sell it...... (allthough, im willing to trade my motor for a carb. 351!)
Ok, changed the fuel filter and the smoke has gone away. But its still having a problem running after I start. I have to rev it over 1g for about 5 mins to get the motor to not stall. I also am hearing a pop inside the motor, almost like its backfiring. My friend says he thinks its chocking out......
I will try the wire/cel light flash thingas soon as possible.....
Thanks for all the help,
Tom
Tom
allright, here are the numbers. this is how many times the cel light flashed inbetween pauses....
engine off- 2 2 2 2 1 2 2 5 12 2 5 1
engine on- 1 2 2 1 9 4 4 4 3 3
Thanks for everyones help!
alright, i found this site that tells you what all the codes are....http://fordfuelinjection.com/index.php?p=14
found out that the egr sensor was having a problem.... found a broken vacuum line and now its a little better.
it also says there is a problem with the MAp/bp, so I will have to get some alcohol and clean the sensors off, and if not im going to have to buy a new one.
it also says the thermactor air injection system problem on both sides= NO CATS...... Im going to have to mod a o2 sensor....
It also says cannot control RPM durring ER self test at high rpm??????
frig.....
Thanks for all your help!
Tom
frig.....
Tom
Alright, just another update.
I pulled the valve covers off, tighened the head bolts. Tightened the lower intake bolts. Still nothing.....
Just for everone who reads this, you should buy a timing light first.
After spending 500-600 on all the parts, parts cleaner, tools, ect....My timing was retarded! Set it to 12 degreese, and now its fast and dosent backfire!!!!!!!!!
allthough a I got really good taking apart the upper intake, it was a pain in the rear!
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
08-10-2015 01:44 PM
