dont know where to begin- please help!
Old 02-02-2008, 09:15 PM
moneypitmustang
moneypitmustang's Avatar
Default dont know where to begin- please help!
[8D]I have an '87 coupe 306. Recently I have put on Paxton Supercharger 6-8lbs of boost. I did all of the necessary changes- bigger fuel pump, 24lbs injectors.When I am in full throttle the car makes great power until 4000-4200 RPMs. Then the car cuts out momentarily.I have plenty of fuel, seems to have good spark- I have an MSD Distributor, and a MSD ignition box. I thought it was the computer and had it dynoed with a custom tune but still having the same issue. Any advice would be appreciated. Thanks, DAN
moneypitmustang is offline
Old 02-02-2008, 09:29 PM
charlesm489
charlesm489's Avatar
Default RE: dont know where to begin- please help!
the more advanced ignition boxes have timing retards and timing advance controls for engines running boost this could be beneficial if you do not have one
charlesm489 is offline
Old 02-02-2008, 09:36 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
What are the plugs gapped at, you may be having spark blow out.
PRO50SC is offline
Old 02-02-2008, 09:42 PM
Novipowered5.0
Novipowered5.0's Avatar
Yep...what he ^ said. Gap your plugs to~ .28-.30 .
Novipowered5.0 is offline
Old 02-02-2008, 11:10 PM
bighungrymatt
bighungrymatt's Avatar
did u get it tuned at all?
bighungrymatt is offline
Old 02-03-2008, 12:51 AM
bikeboy587
bikeboy587's Avatar
clean ur maf or sd sensor
bikeboy587 is offline
