Speedo Gear help!!
Speedo Gear help!!
I own a 95 cobra with an 8.8 rear end. I replaced the original gear ratio with 3:73's. Now my speedo is off. I looked at the Ford racing chart and they do not show a speedo gear available for the T5 5 speed tranny. Can anyone point me in the right direction of finding a gear that will correct my speedo or am I **** out of luck? Any help would be much appreciated.
Thanks
Thanks
RE: Speedo Gear help!!
You'll need to change the drive gear in the tranny also.
http://www.latemodelrestoration.com/...1&comp=LRS
you have an 8t drive gear , thats why...the older t5's were 7t and you needed a 21t to be corrected. if you don't wanna tear the tailshaft off to put a 6t on there you just have to deal w/ it
even a non ford 23t will have you at about 10% error, but your probably about 20-25% error right now
the 23t might not last long though...thats the problem
ORIGINAL: AdderMk2
just change out the drive gear in the tranny... it only takes about 30 minutes
ORIGINAL: nitrous_bob
how do you figure ? i canpull a t5 and get it back in , in about an hour if i am lucky...thats not even counting pulling it apart
ORIGINAL: AdderMk2
you dont have to pull the tranny to swap the gear
yeah i guess, but it seems like it would actually be easier w/ it out.
i only pulled 1 t5 apart ever.... decided it wasn't something i really wanted to do
getting that pin in seems like a b!tch , the steel ball(s) falling all over and stuff...not for me, i'll wreck stuff cuz i get too pi$$ed
anyways, note to those replacing trannys ..... get a 6t drive gear
the steel ball is actually very easy to deal with. and the pin... once you bang it out... it just falls into the shifter valley in the tail case. Once the steel block is removed.. its sitting right there.. staring at you
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
