bellhousing pivot ball adjustible?
i have an quatermaster bell houing for a tko the problem is i cant engage the clutch all the way cus it runs out of room to move foward also my cable isto loose? if i adjust the pivot will this be corrected?
RE: bellhousing pivot ball adjustible?
I am having the same problem with my tremec xxxmustangtxhc. I cant get mine to disengage to shift through the gears not sure if thats what you meant in your post.
I was wondering if an adjustable pivot ball would help.
Thanks
Thanks
1990, 50liter, 95, adjust, adjustment, adjustments, ball, bell, bellhousing, ford, housing, install, mustang, pivot, setup
