Leaking Coolant
Old 02-10-2008, 06:18 PM
mckibben2890
mckibben2890's Avatar
Default Leaking Coolant
I have a 1990 5.0 lx- my coolant is leaking from the right side of the car in line with the 5.0 emblem on the side. its coming out directly on top of where the rear brake lines run (from above). its also leaking on the passenger side where the passengersfeet would be...
mckibben2890 is offline
Old 02-10-2008, 06:19 PM
LTnone
LTnone's Avatar
Default RE: Leaking Coolant
Your heater core died.
LTnone is offline
Old 02-10-2008, 06:32 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
is it coming out of the rubber gommet opening on the firewall on that side?? if so like mentioned above it's most likely a heater core
mjr46 is offline
Old 02-10-2008, 06:50 PM
HACKGT350
HACKGT350's Avatar
sounds like you need a new heater core. have fun with that one
HACKGT350 is offline
Old 02-10-2008, 07:33 PM
mjr46
mjr46's Avatar
pressure test the system and verify where the leak is if you can't narrow it down.. but my guess is it's obvious
mjr46 is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
jerrytubes
10-23-2015 12:11 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Leaking Coolant
