F303 cam with gt-40 heads and intake
hey guys i got a 1991 msutang and im gettting the GT 40 heads and intake and was wondering if the F303 cam would be a good choice! i aslo ahve bbk shortys, with flowmaster 40s and a shift kit? thanks
i triied searching but NONE of my searches work ever??? lol
RE: F303 cam with gt-40 heads and intake
the alphabet cams are quote un quote outdated and alot of better choices out there to max your combos potential out....but I have a f-cam in my 92 with stock ported heads.....mine does okay but a better set of heads would really help my 92's combo out
well the politically correct answer on here is get a custom ground cam taylored to your combo.......a dual pattern cam such as comp xe series are good choices ...like a xe 270 or xe 274....but remember , whatever cam you choose get matching springs for the heads
Comp cams XE series hydraulic rollers. The alphabet cams are ok but with Ford heads they lack on the exhaust side so you need more lift and duration to help with that problem. What are your goals and what are you into, drag racing, hot street, road racing?
Not really much of a problem with AFR's.
i jsut want around like a daily driver nothing extreme! i jsut want like around 260-280 Rear Wheal horsepower so not to extreme what are the specs of rollers do i need so i knwo what to order if i get the Comp XE 270 cam>?
The XE270 is a great choice for a DD. I'd call Comp, Crane, Crower,orLunati and tell them what you want to doand they will reccomendwhat will work best for you. They will also be able to tell you what you need to complement your new cam, valve springs, retainers, locks, etc.
