quick simple question...
Old 02-13-2008, 07:55 PM
DoctorD415
DoctorD415's Avatar
Default quick simple question...
Should you torque the timing cover any, or just snug them on and make sure its centered and on straight?
DoctorD415 is offline
Old 02-13-2008, 07:57 PM
302f150
302f150's Avatar
Default RE: quick simple question...
as long as u know what you're doing you dont have to torque it exactly to spec. the main concern would be cracking it, or gasket bustage, or leaking. then again, torquing it never hurt anything, and u cant ever be too careful
302f150 is offline
Old 02-13-2008, 08:01 PM
DoctorD415
DoctorD415's Avatar
alright thanks, i just wasnt sure if there was a certain torque range you were supposed to stay in or anything.
Old 02-13-2008, 08:02 PM
302f150
302f150's Avatar
Bolts or Parts Lube or Sealer Torque to: Main Caps Engine Oil 70 ft-lbs. Outer Main Cap Bolts Engine 40 ft-lbs. Connecting Rod 260, 289, 302 *289HP and Boss 302 Engine Oil 25 ft-lbs. *45 ft-lbs. Cylinder Heads Engine oil (blind hole) Sealer (water jacket) 70 ft-lbs. Rocker Arms Engine Oil 20 ft-lbs. Oil Pump Engine Oil 25 ft-lbs. Oil Pan Engine Oil 15 ft-lbs. Camshaft Thrust Plate Thread Locker 10 ft-lbs. Cam Bolt (upper gear) Thread Locker 40 ft-lbs. Front Cover Engine Oil 20 ft-lbs. Intake Manifold (Cast Iron Heads) Non- Hardening Sealer 25 ft-lbs. Valve Cover Engine Oil 10 ft-lbs. Flexplate (Automatic) Flywheel (Clutch) Thread Locker 85 ft-lbs. Clutch Pressure Plate Thread Locker 35 ft-lbs. Centerbolt (Harmonic Damper) Thread Locker 90 ft-lbs. Bellhousing (Transmission to Block) Engine Oil 25 ft-lbs.
302f150 is offline
Thunderball
15
11-22-2015 11:49 PM
flash_xx
10-16-2015 07:23 AM
Florida Regional Chapter
09-30-2015 08:04 PM
09-25-2015 06:30 PM
Quick Reply: quick simple question...
