Need help, what is this, its a vac line, where does it go?
Old 02-16-2008, 08:35 AM
tmuti13
tmuti13's Avatar
Default RE: Need help, what is this, its a vac line, where does it go?
It looks like your vac lines are on backwards. The vac line on the left is the one that should go to the charcoal cannister. I justreplaced mine becausemy line was shot. Not sure if it makes a difference though.
tmuti13 is offline
Old 02-17-2008, 07:55 PM
jagman454
jagman454's Avatar
can I leave this thing capped or should I reconnect it?
jagman454 is offline
Old 02-17-2008, 08:02 PM
Liquid_02
Liquid_02's Avatar
EGR is a common debate whether to remove it or not, well in reality, you may notice a slight gain from removing it, but nothing extravagent. The recirculation reduces cylinder temp (slight loss of power, as long as it doesn't detonate) and allows for less fresh air into the engine (another loss of power). Unless you feel like properly tuning the car though (as in an actual dynotune, chip or tweecer), leave it on.
If that's the hose as everybody is saying for the charcoal canister (haven't looked at the pictures) you can leave it capped, and remove the canister. Once again, no power loss or gain from this, just a less cluttered compartement.
Liquid_02 is offline
Old 02-17-2008, 08:56 PM
jagman454
jagman454's Avatar
If i remove the charcoal canister, do I also cap the vapor line comming from the tank?
Old 02-17-2008, 09:05 PM
Liquid_02
Liquid_02's Avatar
Yes, I have a cap on the intake and on the line on my own car
Old 02-17-2008, 09:08 PM
jagman454
jagman454's Avatar
So,
-plug the vac line comming from intake going to charcoal canistier AND
-plug the vapor/fume line comming from the gas tank
-take off charcoal canister
correct right?
just want to make sure I'm doing the right stuff
Old 02-17-2008, 09:32 PM
1991LX5.0
1991LX5.0's Avatar
i dont think you want to cap the vent line, i know when i took my canister out i just snipped the line and let it vent out through the hose, if you cap it the tank cant vent
1991LX5.0 is offline
Old 02-17-2008, 09:35 PM
jagman454
jagman454's Avatar
yea that was on of my concerns, If I delete it though I will prolly try and run it/cut it in the back of the car no where near the engine compartment/drivers cabin
Old 02-17-2008, 10:29 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: Liquid_02
If you cap the line from the tank to the evap canister.....you need to install a vented gas cap or when it gets really hot in the summer and the road heat radiates up from the road onto the gas tank....you could have a recipe for a disaster...as gas vapors are heated they expand..and given the right temp and length of time sitting in a parking lot in the hot summer heat.. I'd reccommend a vented gas cap or leaving line from tank to canister in place..just remove the purge valve and run the line directly to the canister... this was at least the vapors go into something..and or can freely leave rather than build up pressure
mjr46 is offline
Old 02-17-2008, 10:33 PM
jagman454
jagman454's Avatar
could i just let the hose coming from the tank just hang loose? like delete the canister and just leave the hose alone? what ya think?
Quick Reply: Need help, what is this, its a vac line, where does it go?
