Need help, what is this, its a vac line, where does it go?
Old 02-15-2008, 09:18 PM
jagman454
jagman454's Avatar
Default Need help, what is this, its a vac line, where does it go?
the picture is of the front of the intake manifold, I plugged it with a tube and bolt but I want to know where this is supposed to run too and if I should just keep it plugged or not, thanks!
---the vac line is circled in yellow---
links
http://i253.photobucket.com/albums/h...54/tiff059.jpg
http://i253.photobucket.com/albums/h...54/tiff060.jpg
jagman454 is offline
Old 02-15-2008, 09:59 PM
jagman454
jagman454's Avatar
Default RE: Need help, what is this, its a vac line, where does it go?
*bump*
Old 02-15-2008, 10:10 PM
r1pilot
r1pilot's Avatar
I'm pretty sure that goes to the charcoal canister.
r1pilot is offline
jagman454
jagman454's Avatar
?? please explain lol....where?
Old 02-15-2008, 10:16 PM
jagman454
jagman454's Avatar
sO THE EGR system thing then huh?
Old 02-15-2008, 10:17 PM
ALMOST STOCK
ALMOST STOCK's Avatar
It looks like what you've plug goes to the Charcoal Cannister.
The Charcoal Cannister is attached to the frame rail on the passenger side.
ALMOST STOCK is offline
Old 02-15-2008, 10:20 PM
jagman454
jagman454's Avatar
omg thank you, awsome pics, got another question, if i took off my EGR system, can i just cap this or Do I need to tube this guy back to its home?
Old 02-15-2008, 11:07 PM
HACKGT350
HACKGT350's Avatar
ORIGINAL: jagman454
there is no point in taking out the egr system. everyone thinks its gunna free up some hp but it wont. all the egr does is while cruising it recirculates exhaust gas to lower combustion chamber temps to reduce NOX coming from the tail pipes. trust me leave the egr in
HACKGT350 is offline
Old 02-16-2008, 12:25 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
egr actually will help you...IMO.. I'd leave it..it'll help out to lower cumbustion chamber temps by quenching the cylinder temps..helpful if compression is raised
mjr46 is offline
Old 02-16-2008, 07:06 AM
jagman454
jagman454's Avatar
ok but, should I leave the canister valve on my upper intake capped or should I reconnect it?
Quick Reply: Need help, what is this, its a vac line, where does it go?
