T5 5th gear upgrade...
Old 02-18-2008, 03:33 PM
ckyguy68
ckyguy68's Avatar
Default T5 5th gear upgrade...
I want to put a higher ratio 5th gear in my T5 and i dont want to pay Astro gear $265 for theirs. So i was thinking i could use a 5th gear from a different model T5. I think supercoupes had a .80 overdrive... I just want to buy a stock 5th gear for a different model T5 but does anyone know how strong the gear would be? Maybe someone has done something similar and can help me out?
ckyguy68 is offline
Old 02-18-2008, 03:51 PM
stang8689
stang8689's Avatar
Default RE: T5 5th gear upgrade...
Are you road racing it
stang8689 is offline
Old 02-18-2008, 04:00 PM
ckyguy68
ckyguy68's Avatar
No road racing, I just want 5th gear to pull harder. This car is not my daily driver and i have no plans on going 160+ (i pegged my speedo and that was f cuking scarey enough) so i just want a higher 5th gear. I've got my trans open right now and it would be the best time to do it.
ckyguy68 is offline
Old 02-18-2008, 05:38 PM
stang8689
stang8689's Avatar
SVO's have a good 5th for you, 84 has .86, 85 and up has .78
Old 02-18-2008, 06:03 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you mean to want a lower 5th gear.........put a 4cyl tranny in then..it'll achieve the desired effect..I didn't like it so I swapped mine to a 5.0
mjr46 is offline
Old 02-18-2008, 10:29 PM
ckyguy68
ckyguy68's Avatar
Well a higher NUMERICAL gear is what i meantbut i think i will just buy a 5th gearset for a 4cyl then, i was just wondering about the strength of the gear.
ORIGINAL: mjr46
ckyguy68 is offline
Old 02-18-2008, 10:34 PM
mjr46
mjr46's Avatar
you'll be fine as 5th won't take the torque abuse the lower gears will
mjr46 is offline
Old 02-19-2008, 04:18 AM
greenstreak9205
greenstreak9205's Avatar
ORIGINAL: mjr46
shouldn't be a problem. but were not sure if he's gonna slap a bigger shot on that beast now...
greenstreak9205 is offline
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Florida Regional Chapter
09-30-2015 08:04 PM
junior04
09-28-2015 10:53 AM
Quick Reply: T5 5th gear upgrade...
