SMELL OF COOLANT
RE: SMELL OF COOLANT
ORIGINAL: aode08
$10 autozone
Dump dye in the radiator. Drive it around, use the uv light in the kit at night to see what you cant
$10 autozone
when i replaced my thermostat, i payed someone to do it, becase i messed up.
well it leaks a slow drop here and there now, and i took it back, they said "these 5.0's always do that, it would take us another half day to get to it, and it would prob do it all over again"[>:]
its just to much of a hastle to deal with it, and it only leaks a tiny tiny bit, but the smell does **** me off
ORIGINAL: 302army187
yea, im planing on going back there on my days off.
this was last week, and i only had a couple hrs before work, so i just said **** it.
but i dont drive the car that much, so imma see if they will just pull it back off, clean the gasket off, and put on a new one.
that should fix it i hope
ORIGINAL: moterhead
That's a cop-out answer. You paid them to do proper work on your car. 5.0s do NOT always do that. I've owned three of em & never had one leak at the thermostat housing. Don't accept that answer and attitude. Make 'em fix it or give you a refund for the labor anyway.
The dye and UV light kit is a waste of money, you might as well just get a shop to check it for you if you're going to buy that. VERY good kit though. The shop I work at has the kit, I put dye in every fluid in all my cars, and check them on a regular basis. But not practical for an individual to own. What I would do if I were you is just put a piece of cardboard under the car after you park it, and before you go to drive it again, look at the cardboard to see if has any spots on it, then you know where abouts to look for your leak.
what is it with people on here??? you don't need a uv kit to detect coolant leaks on a car..never!!! just a pressure tester and a trained eye!!!! I have always found every external leak with such... if you can't see green then go get your eyes checked
bradleyb
11-27-2015 07:50 PM
