quick question regarding fuel pump...
Old 02-18-2008, 06:05 PM
jrt1990
jrt1990's Avatar
Default quick question regarding fuel pump...
Ok I just installed a new tank, a new fuel pump, new straps, new lines, etc. after my old fuel pump stopped turning on. Tank has no gas in it and I went to turn the key just once and didn't hear anything...thats normal since theres no gas right?
jrt1990 is offline
Old 02-18-2008, 06:08 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: quick question regarding fuel pump...
you should hear it power up briefly.. but I WOULDN'T RUN THE PUMP DRY LIKE THAT!!...and if you were putting a new pump in cause the car wouldn't start?? did you diagnosis the prob/ troubleshoot it correctly to verify the pump was bad???
mjr46 is offline
Old 02-18-2008, 06:18 PM
jrt1990
jrt1990's Avatar
ORIGINAL: mjr46
I know I only did it once lol but ya I wanted to upgrade the pump anyway and I checked the connect back there for voltage when turning on the key so I know its getting electricity...
jrt1990 is offline
Old 02-18-2008, 06:23 PM
87lxBlackWidow
87lxBlackWidow's Avatar
did you check your inertia switch?
87lxBlackWidow is offline
Old 02-18-2008, 06:27 PM
jrt1990
jrt1990's Avatar
ORIGINAL: 87lxBlackWidow
ya that never did anything when I pressed it or do you mean for voltage?
jrt1990 is offline
Old 02-18-2008, 06:51 PM
mjr46
mjr46's Avatar
^^^^if you have voltage at the connector your inertia switch is fine and has not been tripped
mjr46 is offline
Old 02-18-2008, 07:02 PM
jrt1990
jrt1990's Avatar
ORIGINAL: mjr46
lol I figured so...but should I have heard something or should I throw some gas in there and be able to hear? lol its in my schools shop and awaiting a new intake plus its winter right now so itd be all that extra hassle to take some gas in plus it'll be really old by the time the cars running...
jrt1990 is offline
Old 02-18-2008, 07:16 PM
86 5.0L
86 5.0L's Avatar
check the relay under the seat, it should click once, if it clicks more then once the pump isnt turning on
86 5.0L is offline
Old 02-18-2008, 07:41 PM
mjr46
mjr46's Avatar
test for power and ground back at the connector.....just loop the test light
mjr46 is offline
Old 02-18-2008, 07:53 PM
jrt1990
jrt1990's Avatar
ORIGINAL: 86 5.0L
click?
jrt1990 is offline
Quick Reply: quick question regarding fuel pump...
