Blower won't work
RE: Blower won't work
did you plug back in your vac line?
check the white one right behind your glove box
also check all connections there should be a tri wire connection that is your blower motor power. check that
all the vac lines are secure. when i turn the switch tovent it kind of farts, when i turn it to a/c i hear it click once, does this mean i have power? i can't find any loose or open connections...
pull the switch bezzle out and see if you pulled anything looose. also you might need to check some connections for continuity(sp?) you're losing power somewhere it sounds like.
but for some reason i'm suspect of the vac line still.....
