Best intake?
Old 02-19-2008, 10:19 PM
biggmac
biggmac's Avatar
Default RE: Best intake?
On my 92 fox,a Trick flow street intake,70mm T body,H-pipes,(5 speed with stock gears in rear),got me from 15-14.8 seconds in the 1/4 mile (stock),to 13.89 seconds 1/4 mile @ sears point Cali. on a very cold day.A intake on a stock engine does indeed make a difference
biggmac is offline
Old 02-19-2008, 11:24 PM
Mustangkiler
Mustangkiler's Avatar
im with you onyx, why are you using an e cam if you want to spin to 6500? At least get an f cam if you want to be cheap. As for an intake, nothing beats a gt40 tubular intake and will be plenty for a 302 just port out the lower.
Mustangkiler is offline
Old 02-20-2008, 05:24 PM
91lx50udlose
91lx50udlose's Avatar
the reason i want to use the e303 is because i already have 1.7rr and i still have stock pistons and im not just gonna put the intake on a stock motor im doin gt40 irons the intake which im unsure about and a cam also going to do injectors, fuel pump, tb
if you think the e cam is a bad choice do you have any suggestions on a cam with my 1.7's on stock pistons
91lx50udlose is offline
Old 02-20-2008, 05:35 PM
tooslow5.0
tooslow5.0's Avatar
try the trickflow stage 1 cam. thats what i just installed. as for dyno runs, im HOPING to get my car back tomorrow from the dyno guy. hes real busy and keeps pushing back my tune. but as soon as i do, i will be posting my numbers.
tooslow5.0 is offline
Old 02-20-2008, 05:40 PM
91lx50udlose
do u still have the stock pistons with the tfs stage 1 and the 1.7's
I put that cam on a stock motor in my last car but it had stock rocker arms im very curious to see your dyno numbers because im going to run a very similar set up
Old 02-20-2008, 05:42 PM
Mustangkiler
you could use a steeda cam im using those with 1.7s
Old 02-20-2008, 05:46 PM
91lx50udlose
well i would like to have a bigger cam to make more high rpm power but im trying to keep this cheap with stock pistons and just fresh rings and bearings
what about cheap engine kits i found a 347 from coast high performance for $800 with crank rods pistons forged flat tops rings and bearings is there any cheaper than that if so where, and how much is the machine work for a 347
Old 02-20-2008, 08:27 PM
ahaze
ahaze's Avatar
quick question. what is the diff between an e cam and f cam?
ahaze is offline
Old 02-20-2008, 08:52 PM
89mustangfive0
89mustangfive0's Avatar
im runnin the b cam with a cobra and 1.6's makes nice power but im throwin on performer heads and a custom lunati cam
89mustangfive0 is offline
Old 02-20-2008, 09:28 PM
5spd GT
5spd GT's Avatar
E303 - 220*/220* - 282*/282* - .498"/.498" - .311"/.311" - 110* - 110*/110* - 2,500-5,500 RPM
Overlap: 62 degrees.
1.6 Rocker Ratio
Intake Opening: 0* BTDC
Intake Closing: 40* ABDC
Exhaust Opening: 40* BBDC
Exhaust Closing: 0* BTDC
F303 - 226*/226* - 288*/288* - .512"/.512" - .320"/.320" - 114* - 109*/119* - 2,800-6,000 RPM
Overlap: 60 degrees.
1.6 Rocker Ratio
Intake Opening: 4* BTDC
Intake Closing: 42* ABDC
Exhaust Opening: 52* BBDC
Exhaust Closing: 6* BTDC
5spd GT is offline
Quick Reply: Best intake?
