rear main leak?
Old 02-20-2008, 01:35 AM
benjis92
benjis92's Avatar
Default rear main leak?
my mustang has an oil leak at the rear main seal and my mechanic said that that was a common problem for ford 5.0s. he said that the bearings always go bad and then it would leak at the seal. he also said that since i have ported polished heads that that was too much for the bottom end of the motor so it blew the rear main seal. i thought that this was all **** because my motor runs great and has no other problems than that leak. i was wondering what you all thought and if my mechanic was wrong, and also what i should do for my problem. thank you
benjis92 is offline
Old 02-20-2008, 01:40 AM
PJC Racing
PJC Racing's Avatar
Default RE: rear main leak?
Take it somewhere else! ThatA$$clown is not a mechanic!
PJC Racing is offline
Old 02-20-2008, 01:44 AM
Rajun_Cajun
Rajun_Cajun's Avatar
That is one of the most retarded thing I've ever heard. I say do it your self if you have the tools. Its relatively simple.
Rajun_Cajun is offline
Old 02-20-2008, 02:16 AM
benjis92
benjis92's Avatar
i was going to just replace the rear main seal but i was worried that maybe something else needed to be fixed that could have been the cause for the rear seal to leak. please more input you guys are very helpful
benjis92 is offline
Old 02-20-2008, 02:19 AM
primetime5.0
primetime5.0's Avatar
there really isnt anything that will make it leak, they just get old and leak on there own
primetime5.0 is offline
Old 02-20-2008, 02:27 AM
Rajun_Cajun
Are you sure its the ream main seal? Does your clutch slip? Is the oil coming from between the bell housing and the scatter shield? If so, yours is just probably old and needs replacing. Here is a rough guide on how to do it...
1) Pull tranny
2) Pull clutch assembly
3) Pull flywheel
4) Pop out the old seal
5) Coat the new seal with oil and tap into place. Its best to use a flat surface to butt against it so it goes in evenly.
6) Torque Flywheel back into place. Make sure to use correct tq numbers. You can find them on the internet.
7) Should probably replace clutch with a new one. Oil on the discs destroys them
8) Bolt tranny back into place and plug sensors back in.
It should take you about 2 hours depending on your wrenching skills.
Old 02-20-2008, 02:30 AM
PJC Racing
PJC Racing's Avatar
Excess crank case pressure is a contributing factor.If it has alot of miles it may be time for a rebuild, if not check to make sure the PCV system is in good working order.
Old 02-20-2008, 02:31 AM
Rajun_Cajun
^^^^^ +1
Old 02-20-2008, 10:10 AM
benjis92
benjis92's Avatar
its got abt 125k on the motor. and whad u say abt the crank cuz that cudve been what my mechanic was tryin to get at. the oil seems to be coming from the rear main seal and doesnt look like its coming from anywhere else
benjis92 is offline
Old 02-20-2008, 10:25 AM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: benjis92
My mechanic also said that since i have ported polished heads that that was too much for the bottom end of the motor so it blew the rear main seal.
HAHAHAHAHA
[sm=icon_rofl.gif]
AdderMk2 is offline
Quick Reply: rear main leak?
