MAP Sensor
RE: MAP Sensor
RE: MAP Sensor
ORIGINAL: mjr46
so what is the prob? and when does it occur? and what have you tried to correct it??
But so far, ive checked vacuum lines, no cracks breaks or missing lines, cleaned the IAC, Replaced the TPS, Cleaned throttle body, Used fuel injector cleaner multiple times, new fuel filter, plugs, wires, distributor cap, rotor, cleaned battery terminals, new air filter
RE: MAP Sensor
Speed density system or MAF?....... sorry for the link above try this one, and check what failures codes show up.
RE: MAP Sensor
ORIGINAL: 65coupe88hatch
by the "big pack" do you mean the "salt and pepper connectors" the black and whiteish ones?
jwog666
12-27-2021 08:09 PM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
TfcCDR
09-14-2015 12:08 PM
