exhaust under axles
Old 02-26-2008, 10:44 AM
golden_eye
golden_eye's Avatar
Default RE: exhaust under axles
I don't know about the Fox bodies, but it's possible on the sn95s because that's how Ford did the exhaust on IRS-equipped Cobras. The reason for that though was because there wasn't any room to go over the axles (or halfshafts in this case). Unless you have IRS I don't think there's any point to going under the axle though.
golden_eye is offline
Old 02-26-2008, 03:24 PM
FoxGT
FoxGT's Avatar
it was more a matter of convenience. The object was to build a 300hp car for under $2000. I went with a turbo 2.3 engine because when I hit my goal i'll have a gas mileage car. And since 300hp is a cheap & easy task for the 2.3T engines I decided to use it.
FoxGT is offline
Old 02-26-2008, 04:24 PM
uedlose
uedlose's Avatar
Friend of mine ran his under due to the car being tubbed it worked fine a bit strange looking but it worked.
uedlose is offline
Old 02-26-2008, 05:47 PM
aode08
aode08's Avatar
you cant do it at all.
It WILL scrape and hit , driveways and sewer lids.
aode08 is offline
Old 02-26-2008, 07:26 PM
5.0stanger
5.0stanger's Avatar
I don't know why people say it will hit.....if you hung it really close to the axle you will be fine since the tires will go over the bump also and keep the pipe off the ground. Not saying it is a good idea, but how many people have hit the pig on the ground due to speed bumps.....but if you try and lift you car with a lift and let the axle hang, you will be setting right on the exhaust. They can do it with the independent rears since the center pig doesn't move.
5.0stanger is offline
Old 02-26-2008, 11:39 PM
FoxGT
FoxGT's Avatar
I don't intend on doing it anymore. I wanted to steer clear of it for cost being the main thing. Mandrel bends aren't the cheapest thing & having to measure the radius of the bend I need. Just a little hassle. I'd rather not have the bends in this case anyway because of turbo's not being very bend friendly. THe less there were, the better. I think I can live with it though.
FoxGT is offline
uedlose
The Racers Bench
10-01-2015 08:31 PM
b8checker
09-30-2015 07:11 AM
MustangV6P
09-28-2015 11:00 PM
lincolnshibuya
09-24-2015 10:46 PM
09-24-2015 09:18 PM
Quick Reply: exhaust under axles
