cam..
Old 02-25-2008, 07:31 PM
83GT5.0
83GT5.0's Avatar
Default cam..
I've been wanting to get a cam for a while now... but I don't have the money to get the full h/c/i.So, I was going to buy it piece by piece. I wanted somethin that sounds like the E cam, but in the flat tappet version. Is there a cam like that? What would I need to install it so it runs good, pushrods, valve springs, etc? thanks!
83GT5.0 is offline
Old 02-25-2008, 08:47 PM
5spd GT
5spd GT's Avatar
Default RE: cam..
Buy the camshaft last, since you are going piece by piece.
This way, you know you are getting a camshaft to match your combination.
Good Luck.
5spd GT is offline
Old 02-25-2008, 10:52 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: cam..
if your buying flat tappet stuff match up the edelbrock performer rpm kit = heads cam and intake......rpm intake, performer rpm heads and rpm cam = .499/.520 lift I believe.....has nice mild lope and performs well
mjr46 is offline
Old 02-26-2008, 09:37 AM
83GT5.0
83GT5.0's Avatar
Default RE: cam..
Well, I heard that the flat tappet cams in the 83 mustangs sucked so thats why i was going to upgrade it now, and then match the heads with it later.
83GT5.0 is offline
Old 02-26-2008, 10:14 AM
mustangcobra94
mustangcobra94's Avatar
Default RE: cam..
does anyone know how the e cam sounds, im looking to do my cam and want a rough idle sound... can you tell a difference between the stock cam?
mustangcobra94 is offline
Old 02-26-2008, 12:14 PM
w8less
w8less's Avatar
Default RE: cam..
mustangcobra
https://mustangforums.com/m_2658946/tm.htm
w8less is offline
Old 02-26-2008, 12:38 PM
mustangcobra94
Default RE: cam..
thanks jasper ill check it out
Old 02-26-2008, 03:47 PM
OnyxCobra
OnyxCobra's Avatar
Default RE: cam..
E cam definitely has a nice lope sound.
OnyxCobra is offline
95GTofDoom
05-20-2014 08:56 AM
Smashleytulsa
08-28-2013 07:26 PM
braaap-n-trap
351 Mustang
05-20-2011 06:09 PM
fears
06-26-2006 10:26 PM
Quick Reply: cam..
