For those that installed aftermarket dash gauges i need help asap *****
Old 02-27-2008, 08:07 PM
rust_stang
I ♥ Acer
rust_stang's Avatar
Default For those that installed aftermarket dash gauges i need help asap *****
on my fox im installing white face gauges now when i go to take out the instrument panel it wont come out far enough to take disconnect the wires (one on left side of panel and one of bottom right)....i can pull and pull but the wire back there wont let me get the panel out far enough and i dont want to break anything (also i checked and all bolts are out and everything).... any thoughts?
heres some pics of what i mean......in the second pic this guy some how got the panel out far enough before he disconected any wires..[:@]
rust_stang is offline
Old 02-27-2008, 08:18 PM
five0fm
five0fm's Avatar
Default RE: For those that installed aftermarket dash gauges i need help asap *****
try pushing the speedometer cable from outside the firewall...sometimes thats what holds it so close that you cant get your hands behind there.
five0fm is offline
Old 02-27-2008, 08:19 PM
ponyboy302
ponyboy302's Avatar
good luck bro i cant even get off the first cover to get to that point lol
i wanna get rid of that dam airbag bulb !!!
ponyboy302 is offline
Old 02-27-2008, 08:21 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I know it's a tight squeeze sometimes but you'll have to get your hand back there somehow to realase connectors
mjr46 is offline
rust_stang
I ♥ Acer
rust_stang's Avatar
ORIGINAL: five0fm
from like in the engine bay[&:]
Old 02-27-2008, 08:22 PM
mjr46
mjr46's Avatar
ORIGINAL: ponyboy302
^^^^^^^you do realizr that if you do remove bulb then the air bag module will sound off every 30 min!!!
and to the op did you release the speedo cable connection???
mjr46 is offline
Old 02-27-2008, 08:27 PM
rust_stang
I ♥ Acer
rust_stang's Avatar
i cant get in behind the panel to release anything
Old 02-27-2008, 08:35 PM
mjr46
mjr46's Avatar
there are 4 screws holding cluster to dash and the speedo cable doesn't have much slack to pull out on it harder but being careful not to break it... other than that there are just two connectors on the back
mjr46 is offline
Old 02-27-2008, 08:47 PM
five0fm
five0fm's Avatar
yeah from the engine compartment...like mjr said there isnt much slack from it...thats what always holds my cluster so close...sometimes u can squeeze a little more slack out of it
five0fm is offline
Old 02-27-2008, 09:38 PM
ReefBlue93LX
ReefBlue93LX's Avatar
I had to release the speedo cable before I could get mine out far enough to release the connectors...
ReefBlue93LX is offline
Quick Reply: For those that installed aftermarket dash gauges i need help asap *****
