Power Window Not Working
All of a sudden my passenger side window stopped working. if you hit the passener or driver's button for that window there's nothing. No sounds or any movement at all. What is the problem? The motor? Buttons? Just want to get an idea. Thanks.
RE: Power Window Not Working
Check over your fuses...... It's more than likely the motor... If your like me, you have parts laying all around, I would use a motor I knew worked - and I'd hook it up..... If it doesn't do the trick than prob a wire and/or a button.... .. Check and see if the wires are hot.. ALSO, when dealing with FORD electrical systems - consider all/any other electrical problems you've been experiencing.... It'd should be cake.
same thing happened to me not too long ago. asi pulled the door panel off to poke around with a voltmeter, it started working again. no problems after that. guess its just a loose wire somewhere
Take the panel off and pull the motor out. 3 gold looking bolts and a wire connector. Once you have the motor out plug it back up and see if it kinda turns or makes a noise. If it does take out the phillips screw on the black cover where the other 3 bolts were and replace the nylon bushings. You can get these at the dealer. or you can use a more permanent method and use 6 5/16"-18 nuts. Fixes them everytime.
NorthAmericanTuning
03-18-2016 11:21 AM
Mustang Sally72
08-11-2015 07:54 AM
