who's done the 3g alt swap?
Yesterday i did the swap, and everything works great. I followed this link to a "T" http://www.mustangcentral.net/tech/alternator.htmlThis article doesn't say anything about upgrading the alternator ground. My question is should i updgrade the alt.ground using the 4gauge wire also. If so how do i do that?
RE: who's done the 3g alt swap?
Raises a question for me too. I read the article, though I installed a Powermaster 140 AMP alt, I only used the one wire install method that came with the alt. I just tied/taped up the stock connector, put the one wire on the alt bolt and then to battery. There were no other connection points on the Powermaster. Am I missing something???
The alt is grounded through the case where it's mounted. No real need to do anything w/ it. I would/and have upgraded the vehicle ground. Strap from the block to the frame.
Good grounds are one of the most hidden performance and maintenance upgrades.
I have taken resistance values of every Ground this car has, and ended up replacing and modifying, dam near all of em to get em to 0000.
Some had values of 1.23, .947, .009, etc.
After that the car performed like an animal. And Im slammn jams without the headlights dimming, or radio cutting off.
that was very in depth, gonna have to add that to my favorites... then get around to doing the 3G swap....
wonder if advance would take the factory 75 amp back as a core... hell, they prolly wont even know the difference if I come back the next day with the core.... hahah
Matt's 95 Stang
10-05-2015 07:16 AM
