reverse on my 5 speed
Old 03-10-2008, 02:25 PM
Fairlee
Fairlee's Avatar
Default reverse on my 5 speed
Hello all,[/align][/align]I am having issues going into reverse with my 5 speed. I have a 91 gt and to go to reverse I have to shut the car off. Going into another gear first works only half the time. [/align][/align]Is this a normal issue and can this be fixed?[/align][/align]Thanks,[/align][/align]Fairlee[/align]
Fairlee is offline
Old 03-10-2008, 05:25 PM
Jfsram
Jfsram's Avatar
Default RE: reverse on my 5 speed
Clutch is probably not fully disengaging.
How far off the carpet does it start to engage?
Jfsram is offline
Old 03-10-2008, 05:34 PM
WhiteWindsor
WhiteWindsor's Avatar
That is somewhat normal but should not be as bad as you explain. When your trying to get it in reverse ease off the clutch a little and see if it slips in gear.
WhiteWindsor is offline
Old 03-10-2008, 05:38 PM
Fairlee
Fairlee's Avatar
Just in reverse I have to put the clutch right to the floor.
Fairlee is offline
Old 03-10-2008, 06:42 PM
Fairlee
Fairlee's Avatar
To fix this is it just a clutch cable adjustment?
How do you do this? Is it easy.
Thanks,
Fairlee
Fairlee is offline
Old 03-10-2008, 06:56 PM
WhiteWindsor
Look underneath car where cable attache's to the clutch fork and look for a couple nuts screwed onto a long bolt. If not then you dont have an adjustable cable. I'm assuming you still have the stock quadrant. I've read you can pull up on the pedal as far as it will go and the quadrant will adjust itself. An after market quad and firewall adjuster would be a nice improvement over stock.
Old 03-10-2008, 08:21 PM
1992gt400hp
1992gt400hp's Avatar
no man... the stock pedal will get WAY out of adjustment if u do that
1992gt400hp is offline
Old 03-10-2008, 09:21 PM
cleanfitty
cleanfitty's Avatar
ORIGINAL: 1992gt400hp
No it wont...
That IS howyou adjust the factory quadrant.
cleanfitty is offline
Old 03-11-2008, 07:44 AM
Fairlee
Fairlee's Avatar
Iseen the same thing about adjusting the stock clutch in a manual. I will try it.
Thanks all.
Fairlee is offline
Old 03-16-2008, 11:05 AM
Fairlee
Fairlee's Avatar
Tried it and didn't work.
I hope this is just the clutch cable. Sometimes I can get it in reverse easybut most sometimes I cannot without shutting the car off.
What do you guys think?
Fairlee is offline
Quick Reply: reverse on my 5 speed
