What Would You Pay???
Old 10-12-2003, 01:23 PM
95gts
95gts's Avatar
Default What Would You Pay???
Lookin at the sweet 90GT, interested on what one would pay and how the car is set up, the body is in good condition and has a nice silver paint. The hood is a black cowl hood that will need to be painted. It has a very nice stance, I'll try to upload a pic.</P>
<FONT size=4>The new motor is a 306 built by New York Speed. It has ARP rod bolts, TRW forged pistons, SPD Pro molly rings, clevitt main berrings, Ford Motor Sport E303 Rollercam, GT40 cylinder heads, ported and polished, Ford Motor Sport 1.6 aluminum roller rockers, ARP head bolts, Ford Motor Sport push rods, Motor Sport hydraulic roller lifters and retainers, GT40 upper and lower intake manifold, BBK 70mm throttle body with EGR plate, Ford Motor Sport 24lb. injectors, Ford Motor Sport high torque ministarter, Pro M 75mm mass air meter, BBK cold air induction, Motor Sport aluminum underdrive pullies, 3 core radiator, MSD 6AL ignition, MSD cap and rotor, MSD ignition coil, Motor Sport wires, BBK fuel pressure gauge, Kirban aluminum fuel pressure regulator, Cobra black satin valve covers, GMS fuel pump, BBK shorty equal length, ceramic-coated headers, BBK off road X pipe, Flomaster duel chamber mufflers, Cobra R Tremec 3550 five speed trans with Motor Sport clutch and Motor Sport adjustable clutch cable. B&amp;M ripper shorty throw shifter, Ford Motor Sport aluminum drive shaft. The rear is a new 8.8 with 3.73 gears and 31 spline axles, Ford Motor Sport traction loc posi unit, 1 1/2" JBA lowering springs, Lakewood upper and lower rear control arms, welded subframe connectors, ADCO front swaybar with end links and rear Cobra R swaybar. 5 lug conversion with new breaks, new 17x9 chrome Cobra R wheels with 255-40-ZR17 BF Goodrich KD G force tires. Rims are real, not replicas. BBK adjustable chrome camber plates, KYB struts and shocks. 2 1/2" Harwood hood, not painted. Two 2 5/8 white phantom gauges, oil and temperature, new rugs and mats, new clear headlight lenses, and new LX taillights. The car needs a little paint work, but nothing major. New keyless enter alarm. Eclipse stereo system with two 10" woofers. Car is Dynomatted throughout floor boards and behind door panels. Interior panels have some scratches on them. This car wasn't dynoed or raced, but taking a guess it's pushing over 400 horse power. The new motor was properly broken in. It has about 1,500 miles on it so the body of the car has 87,500 miles on the body</FONT></P>
95gts is offline
Old 10-12-2003, 01:25 PM
Jugador1
I ♥ Acer
Jugador1's Avatar
well its all about what you would pay, but i just must say wow...nice *** car...id grab it if u can.
Jugador1 is offline
Old 10-12-2003, 01:35 PM
95gts
95gts's Avatar
7G's is what I'll be paying and with the shipping about $$7700 total.</P>
95gts is offline
Old 10-12-2003, 03:00 PM
95Stealth302
95Stealth302's Avatar
GREAT DEAL DO IT and sell me the parts off your 95 stang
95Stealth302 is offline
Old 10-12-2003, 03:23 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
7-8k</P>
mdvaldosta is offline
Old 10-12-2003, 03:27 PM
frostymug
frostymug's Avatar
the biggest key is how mechanically inclined you are and how much time you got.</P>
With engine costs more than anything else, the old adage holds true: The sum of the final product is greater than the sum of the parts.</P>
frostymug is offline
Old 10-12-2003, 04:45 PM
horatio102
horatio102's Avatar
Que? I'd say you'll never get more for a car than the sum of the parts you put in it. 7-8K sounds like a DEAL. I spent close to 6k on my engine alone (quite a similar setup).
With a higher compression ratio (10:1 or so) I'd think that 400 is entirely possible.
horatio102 is offline
Old 10-12-2003, 05:10 PM
frostymug
frostymug's Avatar
You're right. Speed Shops are in the business of losing money. Nice tax write off
Old 10-12-2003, 05:12 PM
95gts
95gts's Avatar
I'd say I am decently machaniclly inclined, and as far as the time I guess I have decent time. I work a pretty much 7-4 job, have to work weekends every now and then. Why do you ask that. do you think it will break down alot or something, just curious.
95gts is offline
Old 10-12-2003, 05:17 PM
frostymug
frostymug's Avatar
Mostly just depends on whether you think you could build that motor for less. With that being said, unless you have a slew of cars, the whole 'building it is half the fun' line is a load of crap. Definetely not true if you are a one or two car household with time and money restraints.</P>
On another note, GTS's are sweet. I like the sleeper look on them. Also, knew you had to be stationed at Dyess. Not too many people voluntarily move to Abilene. <IMG src=smileys/smiley2.gif border="0"></P><edited><editID>frostymug</editID><editDate>37906.6379050926</editDate></edited>
Quick Reply: What Would You Pay???
