trying to figure out if my clutch cable system is stock or not...PICS
RE: trying to figure out if my clutch cable system is stock or not...PICS
lol ya, and i wish i had at lesat some expiernece with this and i would kno what to do. But theres that nut there on the firewall, if i took that off would there be a way to adjust it or aynthing? Idk i guess somehwere on that firewall is where i have to adjust from, so ill just play around with that i guess.
from what I can see you have a stock cable.. there is no adjustment on that ....that's why it's imperative to have a stock quadrant set up with the built in self adjuster
so where do i go from here? First off will it matter ifi routed it like around the motor mount rather than right underneath it? Would that do anything? Also so if i have the stock cable how do i get this adjusted so my clutch stops slipping?
either get a stock quadrant in there or have someone farmiliar with them look at it to verify what you got and if it's not stock ..you'll need an adjustable cable and firewall adjuster
alright, well if the thing at the firewall is stock, how do i go about puttingan adjust on it? Do i have to take the quadrant and all that off or can i get it on somehow just by taking the end off at the tranny?
You can leave the quadrant on, and just install a firewall adjuster.....and you should be able to get some adjustment...
There are some good directions for install at Maximum Motorsports:
Just go to their site:
http://www.maximummotorsports.com/ and click "Installation Instructions" then "Clutch Cable Firewall Adjuster"
Hope this helps!
Hope this helps!
ORIGINAL: 86 5.0L
just get the firewall adjuster
the stock cable is the strongest cable
