wierd voltage problem
Ok....When the car is sitting in Parkwhile running the voltage is a perfect 14.4 butif put it in driveor pull up to a stop light and sit still while holding the brake and in Drive the voltage drops to like 11.5-12.0 and kind of wanders, Also if iturn the defrost on the voltage goes back up a little higher but still kind of wanders just not as low......If anyone can help It would be greatly appreciated!!!
RE: wierd voltage problem
I just upgraded the alt and only upgrades the 4 gauge wire to the solenoid at first. Then i upgraded theother two of the big three ( battery to engine and engine to frame or firewall). After i upgraded the other grounds it made a difference. YOu want to make sure to upgrade all grounds.
TfcCDR
09-14-2015 12:08 PM
