car wont turn off (and no tach)
Old 03-20-2008, 05:33 PM
DriftingRz
DriftingRz's Avatar
Default car wont turn off (and no tach)
ok so if yall seen my help threads, yall know my car broke like a week ago, it had a gm style dizzy on it, so over the last week we replaced it with a old autolite dizzy , with new points/condensors, msd cap/rotor, and a accell coil. well today i finally got it running right, we had a wire coming off the coil wrong, but it runs now, but the only way to turn car off is to stall the engine. any ideas?
and also sincei had a HEI dizzy on it the tach wire went directly to the distributor,how do i hook it up with this style dizzy, i read somewhere to hook it to positve side of coil, is this right?
DriftingRz is offline
Old 03-20-2008, 05:37 PM
aode08
aode08's Avatar
Default RE: car wont turn off (and no tach)
year make model, mods and engine type etc?
aode08 is offline
Old 03-20-2008, 05:42 PM
DriftingRz
DriftingRz's Avatar
1988 mustang ex 4cyl car
92 gt motor
bbk long tubes
dumped flows
weiand x-cellerator intake manifold
edelbrock carb
Old 03-20-2008, 05:45 PM
Dandy74
Dandy74's Avatar
whats powering up the dizzy when the key is off we should have no power at the coil and dizzy is it not wired to a switched power it should be so when the key is off no power you need a switched 12v source thats all that will keep it running is keeping the coil and dizzy powered up
Dandy74 is offline
Old 03-20-2008, 06:09 PM
aode08
aode08's Avatar
Instead of constant 12+ volts(power at all times), use a test light and find a 12v key on source from your fuse panel and run a wire from there to your 12v+ that you have constant right now.
aode08 is offline
Old 03-20-2008, 06:11 PM
DriftingRz
DriftingRz's Avatar
ill try it out later tnoight, i got a migraine right now, ill update later
Old 03-20-2008, 09:48 PM
DriftingRz
DriftingRz's Avatar
well i got everythng worked out, thanks guys
Old 03-23-2008, 08:58 AM
DriftingRz
DriftingRz's Avatar
where should my Tach wire go?
Old 03-23-2008, 09:01 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
on the neg side of the coil
mjr46 is offline
Old 03-23-2008, 09:08 AM
DriftingRz
DriftingRz's Avatar
is that winking smiley being sarcastic? dont want to short anything out
Quick Reply: car wont turn off (and no tach)
