Electrical Problems
Old 03-20-2008, 07:08 PM
TI302
TI302's Avatar
Default RE: Electrical Problems
how far can you follow your power wires? asuming your problem is near the battery, on a non fused area, id maybe check between your battery and alternator and see if you have a short there, maybe unhook the power wire at the alt.
TI302 is offline
Old 03-20-2008, 07:24 PM
bbbngowc
bbbngowc's Avatar
ORIGINAL: mjr46
check for a short but more importantly with the pos cable on and ammeter connected in series on neg cable ..what is your reading...do you know what acceptable spec is?? it's 25 to 50 milliamps..you need a digital multimeter to run the test set to amps function
I already did this and I'm getting the results you posted.
bbbngowc is offline
Old 03-21-2008, 05:08 AM
bbbngowc
bbbngowc's Avatar
still need help
bbbngowc is offline
Old 03-22-2008, 11:49 AM
Forged331
Forged331's Avatar
Trace you positive wire...your altenator could be shorted also. Unhook the altenator as said earlier and then try to start it up...if it starts, check your altenator wires, if they are good take your altenator to autozone and get it checked.
Forged331 is offline
Old 04-06-2008, 11:36 PM
bbbngowc
bbbngowc's Avatar
In case anyone was wondering ... it was the starter solenoid.
bbbngowc is offline
Old 04-07-2008, 01:46 PM
blackstalion
blackstalion's Avatar
how exactly did u find out it was the starter seleniod?
blackstalion is offline
jma2
07-10-2023 01:00 AM
ak98
02-18-2023 08:36 AM
uberstang1
09-20-2015 06:42 PM
ccdguy
09-19-2015 05:20 PM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: Electrical Problems
