4 Speed to T-5 Help
Old 03-24-2008, 11:07 AM
83FoxBody
83FoxBody's Avatar
Default 4 Speed to T-5 Help
Man, its been a while since I have posted on here.
To the point though... I am trying to swap the 4 speed out of my 83 GT and put in a spare T-5 I have. The four speed is out and I have laid it next to the T-5. One noticeable difference is how the shifter comes out of the tranny. Will this be a problem for installing the T-5? Also, some of the connectors are slightly different. I know this seems vague, but I will provide pictures tonight when I get to my home computer. Does anyone have any experience/advice on this swap?
Thank you.
83FoxBody is offline
Old 03-24-2008, 11:46 AM
ACE
ACE's Avatar
Default RE: 4 Speed to T-5 Help
you need bell housing/flywheel/clutch/t-5 and you are good. It will fit in where the hole is on the floor. You may need to buy plug ends for the t-5 and splice them into your harness
ACE is offline
Old 03-24-2008, 02:04 PM
83FoxBody
83FoxBody's Avatar
I figured as much on the plug ends. I didnt realize the flywheel and clutch were different. I cant keep the ones in there that were used with the 4-speed?
Old 03-25-2008, 11:13 AM
83FoxBody
83FoxBody's Avatar
bump please. Thanks.
Old 03-25-2008, 02:34 PM
302f150
302f150's Avatar
lol, no. an auto technically uses a flexplate. its ALOT different than a flywheel. and an automatic doesnt use a clutch, it has a torque converter. you will also need to install a pilot bearing(i think they are just a bronze bushing on these) in the rear of the crank for your t-5.
302f150 is offline
Old 03-25-2008, 04:55 PM
83FoxBody
83FoxBody's Avatar
I think I just assumed everyone knew I was talking about a "Manual" 4-speed. That, or I'm confused.
So, switching from a 4 speed manual to a 5 speed manual, I dont need a new clutch and flywheel do I? Also, the bellhousing came with the T-5, so I dont need a new one of those.
Any clarity would be greatly appreciated. I'm not sure, but I think there are contradictory posts in here now.
Old 03-25-2008, 07:29 PM
302f150
302f150's Avatar
OH, lol, i figure dyou were talking about the 4speed AOD that came in the cars.....yeah, no clue if you have to change them in that case. you owuld have to make sure the clutch splines fit on your new input shaft, and the pilot bearing fit. if so, i believe you'd be okay
302f150 is offline
Old 03-26-2008, 11:15 AM
83FoxBody
83FoxBody's Avatar
Ok. Anyone else know about this swap for sure?
Old 03-28-2008, 03:02 PM
83FoxBody
83FoxBody's Avatar
bump
Old 03-28-2008, 06:06 PM
ACE
ACE's Avatar
You cannot use the 10 inch flywheel clutch(what you have) with the t5 bell housing because of the way the SROD linkage works. You will need to replace both with a 10.5 inch flywheel and matching clutch.
ACE is offline
UrS4
10-03-2015 06:23 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
BeatnikFink
10-01-2015 08:00 PM
mungodrums
09-29-2015 09:18 PM
musnicki
09-23-2015 07:11 AM
Quick Reply: 4 Speed to T-5 Help
