Vacuum Question
Old 03-27-2008, 12:35 PM
1993 5.0's Avatar
Default Vacuum Question
Is there a vacuum line running into the under side of the upper mannifold? and if so is it accessible without taking off the upper manifold?
I have a vacuum leak and it sounds like that is where it is coming from, I'm going to be getting the stang out soon and that is top on my list to fix this year.
Thanks
1993 5.0 is offline
Old 03-27-2008, 12:51 PM
camaroeater
camaroeater's Avatar
Default RE: Vacuum Question
If its the hose by firewall that runs under intake, I think you would have to remove. As for the other hose that runs under intake in front, you might be able to do it. I need to change the one by firewall. You might as well remove intake,do both hoses, and thow a new gasket on.
camaroeater is offline
Old 03-27-2008, 01:20 PM
tmuti13
tmuti13's Avatar
i replaced the one on the front of the intake that goes to the charcoal canister without removing the upper intake. it was pretty simple, but a pretty tight space to work with.
tmuti13 is offline
Old 03-27-2008, 03:33 PM
1993 5.0's Avatar
ok thanks guys, I will look at both of them!
1993 5.0 is offline
Old 04-02-2008, 08:46 PM
1993 5.0's Avatar
Default RE: Vacuum Question (problem solved)
The vacuum leak was the vacuume line under the upper manifold in the front going down to the canister. It was either dry rotted or melted on the bottom side as soon as I cut the line the car ran so much smoother. I will go get a new hose tomorrow. I can't believe I never found that last year.
I finally gotthe stangout for the first time this year too, ahhh so nice to drive it again.
1993 5.0 is offline
Old 04-02-2008, 10:08 PM
brentloftis
brentloftis's Avatar
Your talking about the line to the MAP sensor right? How was the car running before? I am in the process of replacing mine now due to a rough idle and rich running condition.... very rich. Just hoping I am on the right path.
brentloftis is offline
Old 04-03-2008, 09:58 AM
1993 5.0's Avatar
No, it is the smaller vacuum line. When you look between the upper and lower intake, it is on the left side (if standing infront of the car) it comes out and loops down past the distributor and down to the front passenger side of the car to the charcoal canister(breather canister).
The car would die when started (cold) and then had a rough idle, loped really bad. As soon as I corrected the problem the car idled very smooth.
1993 5.0 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
UrS4
09-30-2015 10:13 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Vacuum Question
