94GT oil pressure concern
Old 03-27-2008, 09:33 PM
Dandy74
Dandy74's Avatar
Default 94GT oil pressure concern
ok so i have 45psi at a cold start and after it warms up 8psihot and 20psi at 2500rpm hot so there is a small amount of rod noise at 3000rpm on decel in park no noise at idle cold or warm can also take it off idle and no noise cold so im gonna drop the member and throw a set of rods and mains in it and a pump any one have any other advice i cought it in time but just wanna get some input oh and it has 80k on it and blows no smoke and the plugs show no oil burning and no puffs in the am start
Dandy74 is offline
Old 03-27-2008, 09:40 PM
306stang
306stang's Avatar
Default RE: 94GT oil pressure concern
8psi is way low. It COULD be your gauge. And if that's the case i suggest getting an aftermarket mechanical gauge.
You should have 10psi per 1k rpm. so you probably should check your seals and oil pump.
Use the search button to get the best results, tons of threads on it!
306stang is offline
chrisdbassplayer
10-13-2015 06:53 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
Teddi
09-29-2015 12:24 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: 94GT oil pressure concern
