hp loss from no tune
Old 03-31-2008, 10:46 AM
89stanger1989
89stanger1989's Avatar
Default hp loss from no tune
about how much hp and i losing from not tuning my car. i have lots of work inside and out but it idles funny here and there. also i just installed a wet nitrous kit and its obvisouly bad to run it on a untuned engine but will she blow. i'm using small jets.i have a superchip on it but doubt that helps.
89stanger1989 is offline
Old 03-31-2008, 11:20 AM
Ridinsidewayz
Ridinsidewayz's Avatar
Default RE: hp loss from no tune
The chip could be a bad thing unless it was tuned to work with the nitrous. It changes the spark timing and fuel curves. If your running nitrous you should run some cooler plugs and retard the timing a bit too depending on how mush nitrous you play to run. Tuning is always a good idea after you add something. If its a minor bolt on taking it in for dyno tuning may be overkill, but it couldn't hurt.
Ridinsidewayz is offline
Old 03-31-2008, 12:35 PM
cholericfc
cholericfc's Avatar
i would get it tuned even if you just installed the chip.... now that you have nitrous I WOULD DEF tune it
cholericfc is offline
Old 03-31-2008, 02:11 PM
bighungrymatt
bighungrymatt's Avatar
you mines well suck it up and get a tune, better safe than sorry!
bighungrymatt is offline
Old 03-31-2008, 07:05 PM
89stanger1989
so i should remove the chip and battery cable so my computer can restart without the chip and dyno tune it. its pretty expensive though. btw i got the chip before i installed the nos
Old 03-31-2008, 07:35 PM
nitrous_bob
nitrous_bob's Avatar
is it a basic chip ? or custom burned for your car ?
if basic...it just advances timing....so yank it and do it yourself
at MOST....your losing 30 hp, and your not really losing it....your not gaining it by burning a custom chip
5.0 doesn't NEED a tune...it'll do it by itself, but you might tweak another 30 out of it
90% of the time idle/drivability issues are vacuum related
nitrous_bob is offline
Old 03-31-2008, 07:45 PM
89stanger1989
5.0 doesn't NEED a tune...it'll do it by itself.....i know computers tune itself but would it be up to my engines level. then what would be the point of a dyno tune?for extra? and with my idle i checked every line in the engine and everything is wired up right except for my ac lines because i removed it
lovesilver
Members Mustangs
05-09-2019 09:18 PM
baddog671
07-26-2016 01:20 PM
Explosive
10-02-2015 07:45 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
RCS02v6
09-29-2015 01:46 PM
Quick Reply: hp loss from no tune
